P0400 code
Old Sep 8, 2007 | 09:20 PM
fritz's Avatar
Default P0400 code
Manual says this is an EGR valve flow malfunction. How do I confirm? Is this a vacuum test or do I blow air into it and determine if clogged? Thanks
Old Oct 2, 2007 | 07:52 AM
2.0_V6's Avatar
Default RE: P0400 code
just disable the EGR. don't need it anyway, plus, u'd get better engine performance.
Old Oct 2, 2007 | 11:42 AM
Poor advice. Dont listen to this person.
You should be able to visually see if it is blocked or not.
Old Oct 2, 2007 | 09:35 PM
Joel_CA's Avatar
It's been a while so i'll and i'm going by memory but if you pinch the vacuum hose near the throttle body (yellow dotted tracer)- it should INSTANTLY stall your vehicle or make it run rough.
JJ
maylene
Jul 12, 2019 10:07 PM
PMR
Oct 8, 2015 08:29 PM
sierrenity
Apr 29, 2009 10:09 AM
Silvertooth
Sep 15, 2007 01:10 PM
mdoc111
May 16, 2007 05:06 PM
