problem in the distributor
Old May 17, 2006 | 01:53 PM
juanfdonoso's Avatar
Default problem in the distributor
Hi guys,
I have a Galant 94 LS. Aparently I have a problem in the distributor. The engine doesn't start. There is no high voltage coming out from the coil. The electrician who checked the problem found that there is not square signal at the inputs of the coil and said that the problem was in the distributor. I removed the distributor to check its parts. Below the rotor, there is a piece like a plate with a connector with 6 terminals. What is it? Could the problem be in there? It is possible to test it? How? Also, I checked the coil and I got 0.9 ohms in its terminals? Are this values correct?
Thank you.
nt_gearheads
Dec 26, 2005 05:21 PM
Jewelz
Oct 6, 2005 10:37 PM
LP
Mar 14, 2005 03:42 AM
LP
Mar 10, 2005 02:40 AM
myspyder
Jun 8, 2004 09:14 PM
