Tachometer wire on 2004 LS Galant
Old Mar 28, 2005 | 12:00 AM
unknown_owner's Avatar
Default Tachometer wire on 2004 LS Galant
I'm installing a remote starter on my 2004 LS and I can't find the tachometer wire. I have two wire diagrams.
One says it a white wire (AC) located at the Engine speed dectection connector (a single pin connector in the fuse/relay box under the hood).
- I can't find the single pin connector. Would the white wore be below the fuse box?"
The other one says the tachometer is NOT black/white or black (ac) located at "any ignition coil"?
- Can't find the coil. I really don't even see the coil.
Anybody can help me? Any pics would be greatly appreciated.
What does the AC mean anyway?
Old Apr 8, 2005 | 03:54 AM
Default RE: Tachometer wire on 2004 LS Galant
Well to help those who might need it in the future, I found the tach signal. The new Galants come with multi-coils and they are located on top of each spark plugs. There are 3 wires for every coil, a BLACK, BLACK/WHITE, and a colored one. Use the colored one for a tach signal. Some of the ones I have seen are BLUE/BLACK, PINK/BLACK, and ORANGE/BLUE.
DON'T use the wires on the fuel injectors; they didn't work.
Old Nov 23, 2005 | 01:34 AM
rganders315's Avatar
I understand your frustration with that. I had the same problem when I installed a tach in my old car. Except for my car you had to use a series of resistors, or the tach would read 1000-2000 RPMS only.
Old Nov 23, 2005 | 02:16 PM
I beleive that AC actually refers to alternating current. To give a tach signal from a single wire it would need to be alternating. The tach would read the number of ocillations and get the RPMs from that.
could be wrong though
Jose_chori
May 31, 2013 07:45 PM
Bugly
Aug 31, 2011 09:20 PM
talontimmy
Jan 26, 2008 12:10 PM
m3kgt_99
Mar 7, 2006 01:11 AM
faded2
Jan 19, 2006 08:43 AM
