Timing Belt
Old Jun 1, 2007 | 04:35 PM
RMUDBUGS's Avatar
Default RE: Timing Belt
No. 1 is the closest to what we do. I work at a Mitsu dealer. If it is a 2.4L than replace the balancer belt too. We usualy replay the tensionor and water pump at the second timing belt job(around 120K).
Old Jun 2, 2007 | 01:42 PM
weigojmi's Avatar
Good to hear. I went with #1 who I had replace the TB and all the drive belts as they were originals.
Old Jun 3, 2007 | 11:15 PM
razvan76's Avatar
A budy of mine has a 2001 Galant and he did just the belt and two weeks later all hell broke loose and messed up ll his exhaust valves. It is a pain to replace all that being so close to the frame and body so if you going to replace all that might aswell do it right and do it all. Get timing belt kit, it will have everything like tensioners and pulleys 70 to 80 bucks, also get the accssesory belt, it's like 10 bucks and the water pump like 80. $180 in parts is alot cheaper then $1200 my budy paid to replace the exhaust valves. Dont cut corners, just my 2 cents dude. Im getting ready to do that to mine. Im on my second engine
Old Jun 14, 2007 | 08:15 PM
jaykumar.r's Avatar
Hi friends,
i have my Galant V6 60K service. a Good auto repair guy in Edison,NJ gave me this quote. Is this reasonable? when i asked him 'does n't timer belt cost about $60?'
He said 'timer belt package' etc ...
part labor total
Spark Plug 28.27 201.60 229.87
Ignition cable 76.80 60.00 136.80
Timer Belt 171.03 252.00 423.03
coolant 100.00
Cabin Air Filter 90.00
Air Filter 25.00
Pepboys gave me $160 for spark plugs & installation. Can I use Bosch 4+ paltinum spark plugs ? Are should I go with Mitsubishi recommended ?
judien
Mar 9, 2018 03:41 PM
marx88
Jun 30, 2011 03:54 PM
8000RPMS
Aug 30, 2007 05:49 AM
agallardo
Oct 29, 2006 11:33 AM
shawnharper
Jan 31, 2005 03:30 PM
