Where do I put transmission fluid?
Old Jan 17, 2007 | 07:22 PM
jaeahr's Avatar
Default Where do I put transmission fluid?
My friend owns a 1997 mitsubishi galant ( automatic ). We're both unfamiliar with cars and have no clue where to pour the transmission fluid and have lost the owner's manual. Can anyone help with the location? Thanks in advance
Old Jan 18, 2007 | 05:46 PM
RMUDBUGS's Avatar
Default RE: Where do I put transmission fluid?
Find the trans. dip stick under the hood then pull it out and pour the fluid in that hole.
Old Jan 18, 2007 | 06:21 PM
jaeahr's Avatar
thats the thing i can't find...i found the oil dip stick but i can't find the tranny dipstick
Old Jan 18, 2007 | 11:52 PM
trident's Avatar
If I remember correctly, the transmission dip stick is to the left (driver) side of the engine. Just use a flashlight and keep looking and eventually you'll find it. If you pull out a dipstick with cherry-red or reddish brown fluid on the tip, that would be it.
Old Jan 18, 2007 | 11:55 PM
davidmitsusrock's Avatar
if its a 4 cylinder...then assuming its the same tranny set up as the 3g eclipse it should be on the drivers side.
jpdaluz
Jul 7, 2015 05:30 AM
newoutlanderfan
May 27, 2013 10:47 AM
jcasaccio
Jun 6, 2006 06:14 PM
jsscott
Dec 20, 2005 05:46 AM
glennsafrit
Oct 25, 2004 12:29 PM
