2009 lancer es stock radio, add an amp and subs?
Old Jun 27, 2009 | 04:36 PM
waldoelx7241's Avatar
Default 2009 lancer es stock radio, add an amp and subs?
how would you wire an amp and subs to the stock sound system, i have the steering wheel contols and i dont wanna loose those, anyone?
thank you!
Old Jul 18, 2009 | 12:53 PM
agent5150's Avatar
I am about to put in a sub and amp on my 09 Lancer as soon as I can get the AMP. lol
I have a friend that used to install car audio from circuit city. He said that you can connect the audio cables directly from the rear speakers to the amp if you are going to be using the stock radio. Instead of running cables all the way from the dash.
Hope this was somewhat helpful.
Old Aug 29, 2009 | 08:41 PM
Toki's Avatar
thank you!
you would need to install a line out converter in the dash behind the stereo(since the speakers are in the doors its the only place to put one)
Old Aug 31, 2009 | 03:25 AM
agent5150's Avatar
Not true. I just wired my amp the other day using the factory stereo. I used some red tap-ins to split the single from the rear speakers directly to the amp. Then I got some gold-plated phono plugs and soldered them to the other end of the audio wire going to the amp. This way there is no need to open the dash at all, and you can clamp the tap-ins anywhere on the audio wire so the only real reason you would need to pop open the door is to make sure you got the right color wires.
Then what I did for the power on wire is wrap it around one of the prongs on the cigarette lighter fuse which is found under the driver side dash. My amp works perfectly like this and I have not had a problem with it.
Old Sep 1, 2009 | 06:55 PM
Toki's Avatar
the problem with doing it that eay is that with out a line out converter you can only get high level output to the amp. I'm not saying it won't work I'm merely saying that its not the best way and you can tap into the ignition switched power to the stereo for the remote line. As a licensed installer that is how I would do it.
Old Nov 2, 2009 | 09:11 PM
Chris152's Avatar
Does anybody have detailed instructions on how to do this?
Old Mar 16, 2010 | 09:18 PM
Miximus's Avatar
Smile RE: how to
i will be installing an amp and sub in my friends lancer in afew weeks, ill post up a how to and some pics.
Peace
WhiteTrash93
Dec 25, 2006 10:34 AM
letsstophere
Jul 29, 2006 03:22 PM
crf_1080
Jan 16, 2006 05:08 AM
Playboy4ll23
Feb 3, 2005 01:13 AM
