can u put a b18 in a lancer es
Old Mar 9, 2006 | 08:29 AM
  #21
Default RE: can u put a b18 in a lancer es
brakes are not the most important the engine management is...will need either the stock ECU from a 4G63 powered car or go stand alone or something. Then I would say ya brakes are a very good idea
Old Mar 9, 2006 | 09:53 PM
  #22
venum's Avatar
ORIGINAL: EMonz57
if you can't stop the car, dont go
but I guess without engine management, you can't go
Old Mar 9, 2006 | 10:25 PM
  #23
ORIGINAL: venum
ORIGINAL: EMonz57
Engine management is some form is a very important thing.... if the motor is all stock then the stock ECU is fine but add some modds and engine manage becomes even more important. that is why I say that over brakes...brakes will cause you to rear end someone without stopping power engine management not being done properly will cause you to need to buy a new motor cuz you can blow a turbo motor really quick if you dont have a good tune
Old Mar 26, 2006 | 05:19 AM
  #24
blkoutride0701's Avatar
no teh 4g63t will notfit the front has a different arm on it and the transmission hast obe larger the F4a42s are so under powered the best swap is a 6G12 or 6G13 ftp motors a B18 is a bigg motor but the engien should fit and i'm not one to dash thingsto pieces the problem is which B18 a/b/c
nyc95gst
Jan 13, 2007 07:34 PM
xplhavoc
Jan 15, 2006 01:31 PM
jfjebers83
Jan 6, 2006 10:01 PM
toicy4ya
May 24, 2005 05:02 PM
spiderrey
Mar 10, 2005 01:45 AM
