changing the 08 shift knob
Old May 22, 2007 | 06:30 PM
Que 8's Avatar
Default changing the 08 shift ****
I have a CVT transmission, and I want to change the **** to a more appealing custom one, but im not sure if I just twist like on some cars. Does anyone know exactly how to take it off (no i didnt try twisting it just yet, I want to make sure thats how its done befor I go ahead and go through with it.)
thank you in advance
Old Jun 29, 2007 | 01:27 PM
AKILEZ's Avatar
Default RE: changing the 08 shift ****
You can't the... shift **** on the stick you can but not the paddle shifter.
Shift **** you can buy a skunk shift **** replacement
Old Aug 9, 2007 | 09:05 AM
jdogg1's Avatar
What shift ***** will fit?
Old Aug 9, 2007 | 09:51 AM
AKILEZ's Avatar
Just twist counter clock wise and and install a new one if you have a manual transmission. There are different kinds but all the samein putting it on the stick.
place the black plastic tip on the stick first. choose the one that will fit and turn it like a nut... clock wise.then put the aftermarketshift **** on the black plastic make sureit doesn't move around if it does put a little black tape around it to make sure it is tight and shift **** doesn't move then put the 3 small screws to tighten the ****, use I think an Allen wrench it comes with ****.
then put the **** cover after you tighten the screws then your done.
CVT is the transmission not the type of transmission like manual or Automatic. cvt eliminates gear whip or neck whip if I call it.
illvibe311
Jun 30, 2006 12:50 PM
04scooby
Feb 11, 2006 07:11 PM
m3kgt_99
Jan 26, 2006 10:24 PM
m3kgt_99
Aug 30, 2005 03:35 PM
jgmacdaddy
Jan 9, 2005 12:49 AM
