headlight help
Old May 4, 2014 | 10:04 AM
Charles Shaheen's Avatar
Default headlight help
hi i'm wanting to buy a set of phillips 100/90 watt bulb for my 2004 lancer es my question is when i buy the 100/90 watt bulb will my stock wiring harness run the bulbs at the 100/90 wattage or will it reduce it to the 55/65 wattage if they will reduce them what can i buy to get the benefit of the phillips bulbs please help asap
Old May 4, 2014 | 04:44 PM
jkeaton's Avatar
Your wiring can't magically reduce the wattage of the bulbs. What will happen though, is your wiring will overheat and melt, possible starting a fire that will burn your vehicle to the ground. If you increase the wattage of the bulbs, you are also going to have to increase the size of the wires for the headlight circuit.
Arty
Mar 28, 2006 10:38 PM
dv8
Feb 28, 2006 08:19 PM
Akmikek
Jan 29, 2006 11:30 AM
unmarked
Oct 12, 2005 12:42 PM
EclipseBabe29
Apr 16, 2005 03:59 PM
