How to Drive your 2008 Mitsubishi Lancer
If you noticed that your Mivec engine lack power.
NOT REALLY....
In order to make it faster.
1.Choose the right gasoline like mid grade and not cheapy generic gas.
if you did notice putting cheap gas or brand feels a little rough not smooth on the gas pedal accelerating.
if you did choose a cheapy gas buy a gas tank cleaner or additives. The Mitsu Manual didn't say anything bad on additives but do it on 25,000 miles not below 25,000 mile. Mine is only 11,000 miles I haven't done it yet.
2. Used premium oil not synthetic if you Drive your Car very hard and change it every 3,000 miles not 6,000 miles.
3. You notice that your car feelsslow on acceleration but not really. The Platform is heavy and feels need more power but actually you are going fast.
4. Drive 4th gear like a Man by putting the pedal to the metal but not rough just gradually.
Do not be Finnesse on the MIVEC it doesn't like it. It was really made for tough people
It is really a Rally Car for the street.
ENJOY
NOT REALLY....
ENJOY
Okay i have a couple issues with the things mentioned.
1) Gas: If it says use premium. Don't use anything else. There should be no question
2) Conventional oil should only be used in the first 1000 miles. After that, the engine needs more protection that conventional oil cannot provide.
I wrote Non Synthetic oil because the Synthetic oil is about $60.00 or more to used every 6,000 miles oil change. The Good but cheap oil are about $25.00 for every oil change that's including oil filter. that's 80 dollars a year oil change A4 times a year oil change.
more if you put 3,000 miles every 2months not 3 or 4.
do the math if you used Synthetic oil every 3 months? that will be a lot of money.
The Mechanic told me that it is not really a big deal. as long you have oil in the engine.
But if you can afford Syntheticevery oil change and then go ahead and used synthetic oil
You can always clean the engine by Engine Flush every oil change that will clean the system but it is really up to you. But not with a newer engine like the 2008 you have to wait until 35,000 miles or up to engine flush it
These are my experiences with my Lancer. Try it and if doesn't work try another cheaper way to oil change.
If you cant afford to maintain it, you shoudnt be driving it.
Your mechanic is wrong, and im comfortable putting my neck on the line for that.
After 1000 miles you should use synthetic.
Ceap = not effective. Synthetic is more expensive for a reason.
Also, fram filters suck! See a previous thread on here about it.
ORIGINAL: AKILEZ
NOT REALLY....
NOT REALLY....
ENJOY
ENJOY
has you're car been talking to you?
Mitsu Tech for 15 years.... cant dissagree.
Im curious as to why yo usaid synthetic is only for higher temps. Does it not provide any added lubrication/metal protection over conventional?
I dont came to INSULT people and I guess you are one of thosePeoplenever had a formal education in College.
You guys so funny.... Some of those I wrote come from the Mitsubishi Manual...did you read instead of Flabbing your mouth like a bitch.
The car doesn' t talk to me dummy
I feel it when I drive it probably you are one those wanna be now how to drive.
I learned how to drive when I was 7 years old with a manual 4 speed tranny. While you were still learning how to catch a baseball.
15 years of a mechanics doesn'r prove anything. If you a Master Mechanic and past the test every year that you can answer me back. Prove it too!!!
Gas is expensive... buy cheapy ones and you will see water in them... dummy that's whatI meant...
Mivec doesn't like it if a driver doesn't know how to drive. Why you people only believe in yourself believe in other people in respect.
The Platform is heavy and the Mivec engine cannot handle itdummy did you noticed that.
Economy Car!!!! why are they selling performance parts for the Lancer!!!!!!
The Manual didn't say You Can only used Synthetic.... Read!!!!
And my mechanic is Certified Master Technician on Watertown Massachusetts Mitsubishi with a degree in Mechanical engineering and he takes the test almost every year.
Go there and asked him..... Please educate yourself and go back to school
Cant afford it and dont drive it
who the hell are you to tell me that....It's my car
Not only saving money it'salso saving the enviroment... dummy
This isa Forum anyway so who cares
ORIGINAL: Sebba
it is ALL marketing hype. Synthetic has only one distinct advantage, and thats its ability to lubricate at ultra high and low temps. Its only a factory fill on cars that will regularly see oil temps in excess of 350 degrees (like the EVO). It has no benefit other than that, and as such 99 percent of the people that use it are wasting money.
it has its place, but its not in a base lancer.
