MZ360272EX Remote engine start problem
Old Feb 14, 2015 | 01:52 PM
alexi's Avatar
Default MZ360272EX Remote engine start problem
Hello,
I have 2009 Lancer 1.8 CVT. I bought remote engine start from E-bay. I put it to my car correctly I am sure abut it. I’m trying to program the remote and everything works as it should but at the end of the key programing the doors are supposed to lock and unlock twice and then the programing is complete. This part is not happening any guidance on what to do would be greatly appreciated ?
Old Feb 14, 2015 | 05:52 PM
2001Mitch3.5XS's Avatar
Have you contacted the make of the remote starter Co....
Old Feb 15, 2015 | 04:35 AM
alexi's Avatar
Installation complated correctly i am sure
After installation
1-Close all doors and remove ignition cnob cap. my car has f.a.s.t. key
2-insert the emergency key into the ignition ****. Turn the **** from LOCK (OFF) to ACC to LOCK repeat this 5 times within 10 seconds, and ecu beeps one time
3- within 10 seconds after the sound of the buzzer, push three buttons and remote light flashing
4 -while the light flashing on remote controller. Insert emergency key into the ignition **** and turn the **** from LOCK (OFF) to ACC to LOCK and than buzzer beep once. Remove key
5- perform the engine stop operation by the remote controller and buzzer beep twice
Everything ok on this point but I can not perform last 6. Step
6- within 10 seconds after the beep, using press the door unlock button three times successively than nothing. it could be doors locks should automatically lock and unlock twice than registration will be complete but my car nothing
Old Feb 15, 2015 | 06:07 AM
Let us know how you make out on the forum bud.
Old Mar 11, 2015 | 02:08 PM
alexi's Avatar
I think, my car remote system works 415mhz and remote engine start 315mhz. I have to change frequency.
Old Mar 22, 2015 | 05:36 AM
alexi's Avatar
i finally did. i change my immo antenna and keys for 315mhz and now remote engine start work perfectly
Old Jan 9, 2025 | 11:34 PM
Lulu_Girl's Avatar
Default 2016 Outlander Sport Auto Start issue
Wonder how you changed frequency for the remote starter. My seems to be faulty as it will only start if I am literally infront of my car, and doesn’t work all the time. I changed my car battery and it hasn’t worked the same since.
Old Jan 10, 2025 | 05:45 AM
Sanguinius's Avatar
have you changed the battery in the fob or just in the vehicle? A battery change won’t change any frequencies and if it starts when you’re in front of the vehicle then it is getting the signal out but it sounds like the signal is weak. Replace battery in remote.
Old Jan 10, 2025 | 06:35 AM
Lulu_Girl's Avatar
Yes I have changed the remote fobs batteries. The only other thing I can think of is, this fall I had my car detailed, I had taken out my two front seats. I connected everything up, but wondering if this would have triggered something.
lucian_v
Nov 29, 2013 11:55 AM
n5926g
Mar 17, 2007 11:10 AM
Fes16
May 17, 2006 01:04 PM
soloRider
Oct 28, 2005 10:32 PM
dariddler
Oct 12, 2004 02:35 PM
