OBD code P0421, whats the fix?
Old Jan 20, 2009 | 09:56 AM
Fe2O3's Avatar
Default OBD code P0421, whats the fix?
02Lancer ES giving me a code p0421: catalyst below temp threshold bank
Search results all over the place seem to vary wildly as to the actualsolutionto the problem as well as the cause:
"Replace your cat"
"Replace O2 sensors"
"Dont do anything, its cold outside, itll go away"
I hate to throw parts at it without a sure diagnosis. Any help appreciated!
Old Jan 20, 2009 | 02:45 PM
mitsupartsman.com's Avatar
Default RE: OBD code P0421, whats the fix?
its the cat...
Old Jan 20, 2009 | 03:43 PM
Manybrews's Avatar
recall on that. call mitsu.
Old Jan 24, 2009 | 07:22 PM
Fe2O3's Avatar
Ok, I did a recall service visit this week. The only things on an '02 are PCM reflash and fan control switch. The PCM reflash might solve the intermittent P0421. I bought an OBD reader and cleared the code. So far after a week it's not coming back.
Old Jan 25, 2009 | 12:18 PM
Manybrews's Avatar
the reflash will not cure the failed cat. It is to prevent the cat from failing.
If you have under 100K on the car, it should have been replaced as part of the recall. If you have over that, its no longer covered.
Old Feb 6, 2009 | 03:53 PM
kevinm's Avatar
what should he do if is over 100000 miles ? replace the cat ?
Old Feb 6, 2009 | 10:41 PM
dsm1990gsx's Avatar
ORIGINAL: kevinm
Cats are covered under fedreal warrany 8 years 80k miles. If your over 100k looks like your paying for it out of pocket.
HydroGuy
11
Mar 1, 2011 04:21 PM
se7en
Oct 6, 2010 10:17 AM
jmil
May 12, 2008 04:21 PM
Stryker
Sep 16, 2007 08:36 PM
jrmdir
Dec 18, 2006 05:49 PM
