Oil Leak Problem
Old Sep 25, 2008 | 04:52 AM
streetglowlancer's Avatar
Default Oil Leak Problem
Just got an oil change a chassis lube and fluids filled and today i installed a new short ram intake and after testing it out i noticed i have a little bit of oil dripping very slowly out of my pan i tightened the bolt or atleast i tried and its pretty tight i am not losing very much oil but it still bothers me when i drip on my garage!!!
other important information: received an oil filter change too
Old Sep 25, 2008 | 07:10 AM
BEAT's Avatar
Default RE: Oil Leak Problem
Oil pan?
That's an easy fix.
Unscrew the bolt and replace the gasket around the oil pan and tighten thebolt with correct factory specification. make sure to check if you need liquid gasketaround the oilpan.
Or check the oil pan and holes where youput the bolts.
if there are cracks you need to replace the whole entire oil pan.
bstarski
Mar 7, 2013 01:12 AM
oscarpro
Feb 27, 2012 03:54 PM
ccernst
Jan 14, 2011 08:38 AM
TheRock0720
Nov 12, 2010 12:30 PM
OZ2003
Nov 26, 2003 10:38 PM
