oz rally 2002 hiccup?? Help!
Old Apr 23, 2008 | 11:10 PM
baltimore's Avatar
Default oz rally 2002 hiccup?? Help!
Hi all I have a 2002 lancer oz rally with the 2.0l engine and 5spd tranny. I recently developed a hiccup in the car. When I shift from 1 to 2nd and goto exelerate it hiccups 2 times and then goes. It also happens in third and forth but only under load. I replaced the spark plugs but did not solve the problem. I am stuck as to what the problem is but do not want to just start putting parts on it. It gets a little costly after a while. It is intermitant only does it sometimes. The car idles fine and runs well at higher rpms but if you slow down a bit and go to exelerate agin it will hiccup ! Any ideas or anybody have this happen to them ?
Thanks any help would be apperciated.
Old Apr 24, 2008 | 11:46 AM
BEAT's Avatar
Default RE: oz rally 2002 hiccup?? Help!
Did you check the park plug when you changed them.
checked for aggressive burn on the spark plug.
Check the fuel line,spark plug wires, etc etc
Tubzor
Oct 18, 2010 10:11 PM
MishartOZ
Jan 30, 2008 11:20 AM
5Tizzle
Apr 19, 2007 06:10 PM
