throttle body replacement
Old Aug 21, 2017 | 11:34 PM
mnamono's Avatar
Post throttle body replacement
Hi Guys,
I'm replacing the throttle body on my 1997 Mitsubishi Lancer CK1A, running a 4G13 EFI economy engine.
I already bought a used throttle body from a used part dealer. Everything is exactly the same accept for the vacuum ports on the top of the throttle body. My current throttle body has 3 vacuum lines connected to it (P, E and something else) whereas the replacement I got only has 1 port while the other two are sealed off. Can I still use the replacement and cap of the other two vacuum lines? I believe these lines are from the EGR
Another option I'm contemplating is rebuilding the current TB using the good parts from the replacement.
Your expert advise will be greatly appreciated.
et2sub
Apr 22, 2005 09:37 PM
1398spdr
Mar 19, 2005 05:12 AM
magno_313
Jan 16, 2005 04:15 PM
Davet2
Nov 18, 2004 01:17 PM
JimmyB
Jun 11, 2004 07:52 PM
