Weak fan in 2004 Lancer/Sportback?
RE: Weak fan in 2004 Lancer/Sportback?
If air volume is weak, perhaps you can check into your AC/cabin filter. If it is blocked with debris, i will strict the airflow coming from the fan. I don't quite remember if the Lancer has one, but i'm fairly certain that the Outlander does. This cabin HEPA filter is a maintenance item and is NOT covered under warranty. Good Luck!
Joel, CA
Joel, CA
ORIGINAL: Joel_CA
Joel, CA
Joel, CA
Who gives a **** anyway. Mitsu hardly ever fixes crap under warrenty so screw it.
It would be really simple to do really. Just remove their resistance circuit from the contacts of the switch and go down to an electrical store and get some resistors and begin!
ORIGINAL: mphil804
If the lancer does have one, where do I try to locate it? I've already checked the "normal" air filter and cleaned it off...but I don't know if there's two filters or just that one.
My car had no problems found except they evapped the r112 and put in new stuff with the addition of a dye to ensure there weren't any leaks. Oh well, it blows a little better now. I'll check my cabin filter anyway to see if it's clogged- with all the dust and dirt in SoCal I'm sure it's dirty.
If the lancer does have one, where do I try to locate it? I've already checked the "normal" air filter and cleaned it off...but I don't know if there's two filters or just that one. If not, then yes, the settings do suck.
Joel, CA
Patrick
24
04-18-2020 06:55 AM
mphil804
15
03-24-2006 04:51 PM
natsu
02-01-2006 01:55 PM
