Weak fan in 2004 Lancer/Sportback?
Old Jul 27, 2006 | 08:31 PM
Default RE: Weak fan in 2004 Lancer/Sportback?
LOL mine is the same way. Im sure you could design your own electrical resistance circuit.
Old Jul 27, 2006 | 11:44 PM
Joel_CA's Avatar
If air volume is weak, perhaps you can check into your AC/cabin filter. If it is blocked with debris, i will strict the airflow coming from the fan. I don't quite remember if the Lancer has one, but i'm fairly certain that the Outlander does. This cabin HEPA filter is a maintenance item and is NOT covered under warranty. Good Luck!
Joel, CA
Old Jul 27, 2006 | 11:56 PM
No what he is sayin is that the air flow settings suck.
Old Jul 28, 2006 | 12:11 AM
mphil804's Avatar
ORIGINAL: Joel_CA
Joel, CA
If the lancer does have one, where do I try to locate it? I've already checked the "normal" air filter and cleaned it off...but I don't know if there's two filters or just that one. If not, then yes, the settings do suck.
Old Jul 28, 2006 | 12:56 AM
Im positive you can rip out their crap resistance circuit and wire up your own
Old Jul 28, 2006 | 01:39 AM
mphil804's Avatar
ORIGINAL: Sebba
Hahah, I wouldn't know where to start. Wouldn't that void the warranty anyway?
Old Jul 28, 2006 | 01:41 AM
Who gives a **** anyway. Mitsu hardly ever fixes crap under warrenty so screw it.
It would be really simple to do really. Just remove their resistance circuit from the contacts of the switch and go down to an electrical store and get some resistors and begin!
Old Jul 28, 2006 | 01:16 PM
dirtwagon's Avatar
ORIGINAL: mphil804
Look in your owners manual to see if your car has one...if it does, that will tell you where it is located and what part number to replace it with.
My car had no problems found except they evapped the r112 and put in new stuff with the addition of a dye to ensure there weren't any leaks. Oh well, it blows a little better now. I'll check my cabin filter anyway to see if it's clogged- with all the dust and dirt in SoCal I'm sure it's dirty.
Old Jul 29, 2006 | 10:37 PM
Joel_CA's Avatar
If it were to have one, it would be located in the area behind the glovebox just above the actual blower motor. The "normal" air filter located in the engine compartment is strictly for the engine's intake and has nothing to do with filtering the air inside of the cabin.
Joel, CA
Patrick
24
Apr 18, 2020 06:55 AM
SRC1225
Jun 17, 2013 02:23 PM
mphil804
15
Mar 24, 2006 04:51 PM
natsu
Feb 1, 2006 01:55 PM
natsu
Oct 4, 2005 06:01 PM
