2001 Mirage engine cuts off
Old Mar 30, 2013 | 06:06 PM
Farmer44's Avatar
Default 2001 Mirage engine cuts off
The car will start and run fine. If I cut it off and come back to cut it on 10-15 minutes later it starts but only runs for a couple of seconds then stalls, if I bump the ignition it will continue to run but only a few seconds then it stalls again unless I keep bumping the ignition. After it sits for 45 min to an hour it will start and run for at least 1 hour or so. It has stalled after driving for couple hour of running. Help much appreciated.
Old Apr 2, 2013 | 08:26 PM
go-part's Avatar
Former Sponsor
It sounds like whatever part you continue to bump is failing once warmed up.
Replacing it should fix your problem.
shellbell
Apr 21, 2010 11:31 AM
eclipseGS98
Oct 19, 2007 09:28 PM
embryriddledude
Jul 11, 2006 09:37 AM
toneee
Feb 2, 2006 03:11 PM
BptEclipse
Jun 27, 2005 07:21 PM
