2001 mirage help plzzzzz
Old Oct 11, 2009 | 06:04 PM
Sudeep's Avatar
Exclamation 2001 mirage help plzzzzz
Hey guys, i have 01 mirage ES Manual transmission with 80000 miles on it.....the car recently started to overheat at idle. It drinks a lot of coolant i dont know why. There are no leaks under the car. I got a check done at firestone and the car failed the pressure test. Also i noticed that the oil is really low on the car now. The coolant in the radiator is kinda thick light brown in color.
Please help me out with this....i dont know what the problem is
Old Oct 11, 2009 | 07:14 PM
dsm1990gsx's Avatar
Does it smoke at all? Try a compression test sounds like you have a blown head gasket.
Old Oct 11, 2009 | 07:22 PM
Go to autozone and pick up a compression tester for $20.
Old Oct 11, 2009 | 11:27 PM
Sudeep's Avatar
no it doesnt smoke at all. I got the pressure test done at firestone. is compression test something else??????
Old Oct 11, 2009 | 11:28 PM
Sudeep's Avatar
i want to know if it is really serious that i should sell the car.....
Old Oct 16, 2009 | 07:55 AM
MacGruber's Avatar
a head gasket is not an easy job for a beginner. Alldata calls for 5.4 hours of labor (if the car has A/C) and figure roughly $150-$200 for parts. At a labor rate of $100 per hour, which is cheap some places, you're looking at a $740 job easily.
Old Oct 17, 2009 | 12:41 PM
Do the compression test yourself. I don't know what test they performed at firestone.
Old Oct 17, 2009 | 12:52 PM
dsm1990gsx's Avatar
You should have done the compression test not the cooling system pressure test.
Hupowers
Apr 30, 2008 08:47 PM
josetello72
Jun 29, 2006 02:08 PM
easter85
May 21, 2006 12:38 AM
Powertech
Mar 29, 2006 01:10 AM
Lowdown
Oct 10, 2005 05:59 PM
