Clutch Adjustment Location
Old Jan 13, 2008 | 06:24 PM
Jaygee61's Avatar
Default Clutch Adjustment Location
Hey ya'll!
I have a 1990 Mirage, standard, 1.5L. This model does not have the hydraulic clutch (at least according to my Chilton's). My problem is that my clutch pedal is going all the way to the floor and barely engages the transmission. I'm pretty sure I just need to adjust the cable, but all the Chilton says is thatthe adjustment nut islocated "at the firewall", no diagram or other description.
Is this adjustment under the dash or in the engine compartment? Help!
Thanks!
Old Jan 14, 2008 | 08:50 AM
BEAT's Avatar
Default RE: Clutch Adjustment Location
Well check the firewall in the engine first. if not check the inside ofyour car.
always check bought if you are not sure.
Old Feb 1, 2008 | 10:25 PM
jgbrules's Avatar
hello. the clutch cable comes out of the fire wall on the drivers side. you have to grab the cable itself and pull it, so it frees the adjuster wheel. turn the adjuster wheel in, meaning going twords the firewall. that might give you a little time, but not much. when you have that much play in the pedal its gettin time for a new clutch!! good luck!! greg
Wi_Fibre
Oct 18, 2007 10:36 AM
kleathers
May 11, 2007 07:59 PM
brob13
May 4, 2007 03:46 PM
sodian
Oct 7, 2006 09:05 PM
Lefty
May 27, 2004 03:43 PM
