Smoking out of the exhaust
Old Apr 9, 2006 | 11:13 PM
stuiloui's Avatar
Default Smoking out of the exhaust
I added oil to my car that burns oil and after driving down the road a bit I started to smoke out of the exhaust. One day last week after adding some oil the car started over heating but my coolant level was full. After the second time adding oil the coolant was still full and the car was not overheating at the time it started to smoke out of the exhaust. I am wondering if this could have been because I added to much oil. If so what can I do now????? Also the car started to leak oil after the second time adding it. Any suggestions????
Old Apr 9, 2006 | 11:31 PM
dirtwagon's Avatar
Default RE: Smoking out of the exhaust
Check you oil level. Are you adding because you think you need it or because you are checking the dipstick properly and it says you need it. I believe from the fill line to the full line is one quart of oil.
What color smoke is it coming from the tailpipe...possibly blown headgasket if white. Check the oil filler cap, if it looks like water droplets are inside or on the filler cap or milkshake consistency; may be time for a new headgasket.
Check your radiator cap..pressure test or buy a new one.
Check thermostat.
Check for where the engine is leaking oil...valve covers, drain plug, dipstick, etc.
Old Apr 10, 2006 | 12:52 AM
stuiloui's Avatar
IT is like a light blue/greyish color. I was adding oil because the car burns it and needs it. What do you think now????
Old Apr 10, 2006 | 12:47 PM
What car do you have. I recomend doing a compression test. You may have low compression in one of the pistons that is causing you to burn oil.
Old Apr 10, 2006 | 07:12 PM
dirtwagon's Avatar
Did you check the components of the cooling system yet? Radiator cap is cheap...$6-10 if needed, may not be holding pressure properly. If you have coolant with no leaks, than you have a problem with the system itself. Is your fan coming on? Is your radiator clean of leaves\debris? What is the ratio of coolant to water? Is there any part of the front fascia missing from the car? Some of the older Camaro's(80's) would overheat due to the black plastic piece getting torn off coming in/out of driveways and parking lots and therefore the air wasn't being routed to the radiator by the deflector.
Old Apr 18, 2006 | 12:10 AM
00Mirage's Avatar
my guess would b u added to much oil.
Shadow
Feb 24, 2008 11:51 PM
vj_eclipse
Sep 17, 2004 11:07 PM
sesoler
Jul 27, 2004 10:13 AM
dencomtech
Jun 26, 2004 04:36 AM
Seth
Apr 24, 2004 02:19 AM
