sputter and TPS
Old Jan 10, 2009 | 09:40 PM
tinyavenger1's Avatar
Default sputter and TPS
got a 98 mirage sedan DE with 80k on it. when i bought it it ran fine for about 2 days then it started to stutter at low rpm'sand the engine light was on. took it back and the code was for cylinder misfire and TPS. they replaced the cap (has new plugs and wires) and that solved it for about a day. my fiance took his cobalt to get some exhaust work done at buckys and they checked my car and adjusted the TPS. now it revs at about 2000rpm at idle and stutters at low rpm when cold. any suggestions on stutters solution and how to adjust the TPS so it idles lower would be greatly appreciated!!!
Old Apr 18, 2009 | 04:23 PM
BFrosty95Rage's Avatar
On the throttle body by where the intake attaches should be a screw head (it is phillips) on my 95. Try screwing in clockwise to lower idle speed.
Owen_Mirage
Mar 23, 2014 02:18 PM
fleshbone
May 25, 2009 09:53 PM
itsme71190
Mar 7, 2008 08:42 PM
Wi_Fibre
Oct 17, 2007 03:21 PM
Dookitchen
Oct 1, 2006 09:13 PM
