RE: "D" light on my Gauge cluster
ORIGINAL: smoerbe Sorry. It's a 2001 Montero Limited. Do you have a copy of the Factory Service Manual? It's usually a couple of hundred dollars but if you're looking to do your own repairs in the future, it's worth double it's weight in gold. If you want to do common occassional repairs then a Haynes/Chiltons manual may suffice. I've got the Haynes for a Gen I and the FSM for the Gen I & Gen II. I don't have it for the Gen 2.5's or the Gen III's. |
To access the instrument panel on a Gen III;
There are two screws for the instrument cover cluster, one above the speedo, one above the tack. After you remove those two screws the assembly should pull out. Once you have the cover off, there are four screws holing the gauges in place. Remove the four screws and you should be able to pull out the gauge cluster and access the bulbs. |
Hi! just noticed this thread, I have a 2002 Montero Limited, and my D light is out also. If I want to get a brand-new bulb (as opposed to using the one from first gear), does anyone have the part number for OEM please? I have the part number for the 4x4 light (MR444536), but that one might be a bigger bulb than the D. Thank you!
Reply to why the ,"D, is off on dash for montero, ALL MODELS
Originally Posted by ole
(Post 16853)
Just had the 4wd and the ABS lights fixed on the transmission, They were flashing and there were switches replaced that sit on the transmission. Now I notice after the work that my "D" light does not light up. Is this too a bulb problem or could they (dealer) screwed up somthing up?
Thax:eek: |
