"D" light on my Gauge cluster
Old Feb 14, 2005 | 02:32 PM
Pajoz's Avatar
Default "D" light on my Gauge cluster
Guys, can someone help me on my D light in the instrument panel...all the lights are working(P, R, N, 2L) except for D.
Does it has a seperate bulb??? How to change DIY. Thanks
Old Feb 14, 2005 | 03:00 PM
Winshawn's Avatar
Default RE: "D" light on my Gauge cluster
Yes, it is a separate light bulb. This is fairly common since the "D" bulb is used the most often.
Old Feb 15, 2005 | 01:36 AM
Pajoz's Avatar
Thanks winshawn, is it easy to replace DIY. Is the bulb the same with compass guage?? Any part no.?
Old Feb 17, 2005 | 05:08 PM
Winshawn's Avatar
I do not know the part no. Just go in and take the light from gear no 1 and put it in the D spot.[8D]
Old Feb 21, 2005 | 01:23 PM
tonton's Avatar
Good idea!
I got a handful spare bulbs from the local scrap merchant for next to nothing.
The cluster comes out easily, give it a go.
Anton
Old Mar 7, 2005 | 11:51 PM
ole's Avatar
ole
Just had the 4wd and the ABS lights fixed on the transmission, They were flashing and there were switches replaced that sit on the transmission. Now I notice after the work that my "D" light does not light up. Is this too a bulb problem or could they (dealer) screwed up somthing up?
Thax
Old Mar 11, 2005 | 01:46 PM
Pajoz's Avatar
try check the bulb also, i followed winshawn's advice to get the bulb in gear 1.. its easy diy, 5 minutes job.
Old Oct 27, 2005 | 12:54 PM
smoerbe's Avatar
My wife's Montero has the same problem. The D light and the light representing rear pass. wheel are both out. What do I need to remove to get access to this area?
Old Oct 27, 2005 | 04:53 PM
off roader's Avatar
Year & Model of vehicle might be helpful...
I suspect however the guage cluster will need to be disassembled to some degree. Shouldn't be too hard. Not too many moving parts there that you will disassemble.
Old Oct 27, 2005 | 07:14 PM
smoerbe's Avatar
Sorry. It's a 2001 Montero Limited.
