**Please Help Problems W/ 2000 Montero Sport**
Old Jan 6, 2011 | 09:02 PM
wjelmer's Avatar
Default **Please Help Problems W/ 2000 Montero Sport**
I'm having issues with my 2000 Montero Sport 3.0. Car runs fine for about for 5 minutes then wont go faster than 2mph and starts to chug and will eventually stall. Took it to a mechanic said the Mass air flow sensor was bad, I replaced that and still having the same problem. If you unplug the mass airflow sensor the car runs fine but at low rpms. With MASF plugged in no check engine light and scanners are not reading any codes.
Please Help
Old Jan 6, 2011 | 09:40 PM
johnoutdoors's Avatar
Look at the ECU side of the plastic connector for MASF. Are any of the pins loose or corroded? I had a Mazda that was doing the same thing, they had run the wires too short and over time the pin worked its way out of the back of the harness. Good luck.
Old Jan 7, 2011 | 03:40 AM
wjelmer's Avatar
been reading up and she just had the alternator replaced may have crossed cables when the battery died. Someone says its Fuel consumption unit? does that sound right?
Old Jan 10, 2011 | 01:42 PM
codeaholic's Avatar
Testing the MAF is easy. Plug the MAF in, rev the motor with the car parked...when you hear the problem. Unplug the MAF, if suddenly the more fixes itself, poof, its bad. If the computer is relying on the MAF, the motor runs like crap. As soon as the computer sees the MAF is off line, it will calibrate itself to account for that and give itself some parameters where the motor will run but way below peak performance specs.
With the MAF unplugged, you should be able to drive around. Your gas mileage will suck and the car will not be a hot rod but it should be driveable.
jimithing27
Apr 16, 2021 12:17 AM
Mark53
Aug 1, 2014 08:34 PM
2000montero
Jan 3, 2014 07:01 PM
JFENDERSON91
Oct 10, 2012 11:24 AM
jp2000
Jan 1, 2012 05:21 PM
