00 Montero Sport SRS light on ????
There are impact sensors in and around the front bulkhead and frame tubes. Not sure if they are near the compressor but if you also changed out the A/C dryer it possible you may have disconnected a wire somewhere? Also, for any reason did you have the steering wheel off?
If you turn the key on with any component disconnected it will set the SRS light. Even when everything is hooked up again you'll have to go to a dealer or other mechanic with a Mitsu scan tool (MUT) to have the error cleared - so you might want go and have them pull the codes and identify the source of the problem.
[I changed out my transmission filter and this SRS light has popped up. That won't keep it from starting will it. I'm thinking the battery might just be drained but I want to make sure.
whippau
Jul 1, 2011 11:20 AM
3000GTrallyarts
Jul 26, 2010 06:50 PM
