00 Montero Sport SRS light on ????
Old Jul 25, 2008 | 12:38 AM
mallely1's Avatar
Default 00 Montero Sport SRS light on ????
I just changed out my A/C Compressor and when I finished the SRS lightcame on, can any one tell me what the SRS light is for and how I can fix it ??? please
Old Aug 9, 2008 | 04:55 PM
mallely1's Avatar
Default RE: 00 Montero Sport SRS light on ????
N-E one ???????
Old Aug 9, 2008 | 05:14 PM
dsm1990gsx's Avatar
The srs light is for your air bags.
Old May 23, 2013 | 07:08 AM
jrmdir's Avatar
There are impact sensors in and around the front bulkhead and frame tubes. Not sure if they are near the compressor but if you also changed out the A/C dryer it possible you may have disconnected a wire somewhere? Also, for any reason did you have the steering wheel off?
If you turn the key on with any component disconnected it will set the SRS light. Even when everything is hooked up again you'll have to go to a dealer or other mechanic with a Mitsu scan tool (MUT) to have the error cleared - so you might want go and have them pull the codes and identify the source of the problem.
Old May 4, 2019 | 02:36 PM
Brayant Q. Monroe's Avatar
Default Will this keep the vehicle from starting?
[I changed out my transmission filter and this SRS light has popped up. That won't keep it from starting will it. I'm thinking the battery might just be drained but I want to make sure.
whippau
Jul 1, 2011 11:20 AM
3000GTrallyarts
Jul 26, 2010 06:50 PM
shum_87
Aug 29, 2009 05:05 AM
pgb205
Jun 4, 2009 10:40 PM
r2ritu
Feb 1, 2007 06:43 PM
