02 3.5 sport leaking oil at head gasket, anyone ever see this issue?
Old Feb 23, 2015 | 08:29 PM
canoeman22's Avatar
Default 02 3.5 sport leaking oil at head gasket, anyone ever see this issue?
We've taken our 02 Montero Sport in to have the timing belt, seals, water pump etc replaced along with new valve cover gaskets. Everything has been replaced but the mechanic has been chasing an oil leak. He thinks it's coming from the front of the head, left side when looking at the engine. He's finding oil just below the cam seal. He wants to pull the head off and replace the head gasket. I'm concerned that what we actually have is a leaking valve cover that's seeping out and appearing at a low spot on the head. The engine only has about 90k miles and has never run hot as far as we can tell.
Has anyone else seen a head gasket leak oil on one of these engines? We're not seeing any oil water mixing in the engine or radiator. anyone know if there are any oil return holes on the end of head?
Old Feb 24, 2015 | 01:01 AM
An oil leak on the front of the engine is likely to be coming from a front cam seal. By any chance are you getting oil onto the alternator?
Don't pull the head, replace both cam seals.
Old Feb 24, 2015 | 01:29 AM
Akzle's Avatar
i'd be hunting frost plugs. or, the cam seal.
if the valve cover seal has just been done (properly) it shouldn't be leaking.
Old Feb 24, 2015 | 06:19 AM
canoeman22's Avatar
The cam seals have been replaced. The mechanic used UV dye and couldn't see any oil leaking from the cam seal
Old Feb 24, 2015 | 09:18 PM
The freeze plugs do not connect to oil passages. There is coolant behind them.
Old Feb 24, 2015 | 09:19 PM
Was he able to see where the leak was coming from the head with the UV dye?
Old Feb 25, 2015 | 12:14 AM
Akzle's Avatar
hat's off. correct.
i'm sure he went back to edit
Old Feb 25, 2015 | 12:51 PM
canoeman22's Avatar
He says they can see it seeping out right at the bottom of the head, just below the cam seal. I'm just worried that's weeping in from somewhere else that they're missing and showing up at the bottom of the head. The actual head gasket leaking seems to be a very rare problem.
montey cosmopolitan
May 3, 2015 08:46 PM
XeoNoX
Dec 27, 2012 01:38 PM
EMonz57
Oct 18, 2008 10:58 AM
dsm1990gsx
Apr 28, 2008 08:21 AM
chrisg
Mar 29, 2005 06:42 PM
