02 Limited Strange sound in the right bank
Hi everyone, as it says in the title, the right bank has a strange noise, most prominent when the engine is cold and under a load. Sounds like a cross between clicking and forced air. Nothing like noisy lifters. I used to think it was an exhaust leak around the catalytic converter, but upon closer inspection it is definately internal. I should add that it has 175000 mi, has spent 5 years in alaska, and made the 5000 mile trip twice. I can't tell if it is in the head, which would be better than piston slap. Anyone had to address something like this? I am mechanically inclined, but I have never heard piston slap for myself and am not ready to just make a blind diagnosis. Maybe I should just by a borescope and take a look in the middle cylinder, which I believe to be the culprit.
I am of your way of thinking entirely, I spent some time contemplating because I was so sure it was an exhaust leak when I first heard it. I cannot find it, try as I might. That leaves only a crack under the heat shield as a possiblity if it is an exhaust leak. I will pull it off this week and post what I find. It would not be a big surprise as the two 1g eclipses I had adopted in the past both had cracked manifolds. Thanks for the input...
I pulled the heat shield off of the right exhaust manifold and there was no need for sea foam. Big crack laterally behind the middle oulet. I am going to buy a new exhaust manifold today along with a few other projects for the truck.(new belt, tensioner, and idler pulley) Thanks for the help.
Well, there's no reason to do both if only one is cracked. I don't have to remove anything major to replace the right side. If I had to pull the intake manifold for both, then I definately would, but as it stands....
