02 Montero XLS - 4WD Selector Swith Is Bad - How to Replace?
Old Nov 4, 2011 | 06:49 PM
absorrel4's Avatar
Default 02 Montero XLS - 4WD Selector Swith Is Bad - How to Replace?
I have a problem with my 4WD engaging and have narrowed the problem down to the selector switch. When I select 4WD via the handle within the drivers cab, the 4WD engage lights jump on and off...sometimes they flash and sometimes the 4WD is fully engaged and then shuts off. I can actually hear the switch below the handle click on and off. It sounds like the switch is just below the console. If I physically hold the handle in a certain position, the switch stays on and the 4WD is fully engaged...but, when I let go of the handle the switch shorts on and off. I need to replace this switch. How do I do it? Can I take the console out and access the switch from above?...is there an easier way? Thanks for your help...
Old Nov 5, 2011 | 08:54 PM
Mr. Z.'s Avatar
You can access the FSM in PDF format at the following site.
Follow the link to the Pajaro Gen. III.
Pajero 4x4 Off-Road Club 2000-2008
If you want OEM parts, here is a link to an on-line source.
https://www.mitsubishiparts.com/oe_parts_catalog.html
Since you are servicing your system, you might think about a fluid change in your transfer case if it's been a while.
Good Luck
Old Nov 5, 2011 | 09:47 PM
absorrel4's Avatar
Thanks for the info. I went to the link you provided and it is all in Russian language. I followed every link that had anything with Pajero III in it (and many other links) but I couldn't find a pdf and all the language is in Russian. Any suggestions?
Old Nov 6, 2011 | 09:33 AM
Mr. Z.'s Avatar
Here is the link to the FSM.
It's for an '03, but the transfer case is the same for both years.
http://www.pajero4x4.ru/piii/
Old Nov 6, 2011 | 11:58 AM
absorrel4's Avatar
Lots of good information....thanks...
Dolbydigital
Oct 27, 2014 09:07 PM
germanshepherd
Mar 11, 2012 02:28 PM
tw0000
Dec 12, 2011 05:11 PM
koloaman
Oct 3, 2011 06:33 PM
greengrounds
Jan 20, 2010 06:59 PM
