03 Montero Sport won't blow heat...at idle
Old Feb 9, 2011 | 07:46 PM
busdriver9's Avatar
Default 03 Montero Sport won't blow heat...at idle
03 Montero Sport...it only blows heat after driving for several minutes. I started the MS 25 minutes before leaving the house. when I get in the ride it is still blowing freezing cold air. almost immediately heat come out, however if I stop, it goes cold! any ideas. I am thinking maybe heater core or clogged lines to heater core!?!?! am I on the right path?!?!?!?
thanks in advance
Chris
Old Feb 13, 2011 | 08:33 AM
busdriver9's Avatar
Angry
so I guess this has never happened to anyone? I just replaced a CV shaft, getting ready to do valve cover gaskets as soon as it warms up a little more! I just feel lost on this heater issue!
Old Feb 14, 2011 | 01:46 AM
mitsustigi's Avatar
thanks in advance
Chris
Hi Chris,
Sounds like a clogged line/heater core. Cannot say for sure as you do not provide much in the way of information - mileage, coolant change schedule, type used, etc. I would hate to think that it is a failing water pump.
Have you tried looking at the Montero sport factory manual?
Cheers,
Farhad
Old Feb 14, 2011 | 08:07 AM
busdriver9's Avatar
Originally Posted by mitsustigi
Hi Chris,
Cheers,
Farhad
sorry....it has 70k miles on it, coolant has just recently been changed but has not ever been flushed. I changed it when I started taking care of it(it is my wife's car), this winter, but I really just did a quick change because it was freezing outside. I am not a hundred percent sure of the type used but it was what Advanced Auto Parts computer said to use (GREEN, if that helps) Needless to say this car has not been taken care of well (don't tell the wife I said that though)! She has just taken it to a quick oil change place for oil and fluid refills but never any of the extras. I am not familiar with Mitsubishi vehicles but can find my way around my truck pretty well, so I am sure I can tackle most of the problems myself! As for the manual I have found one online http://www.pajero4x4.ru/piii-pdf/PrefaceForMMSAVol4.pdf
-Chris-
Old Feb 16, 2011 | 11:41 PM
SSfanatic's Avatar
Sounds like you got an air bubble. Let the car cool down, open the bleeder and remove the radiator cap. Add coolant until coolant starts coming out the bleeder hole. The bleeder is on the engine right next to where the radiator hoses go into the engine. It's a short 12mm bolt with a black plastic sealing washer. Start there and see if that helps.
Old Feb 17, 2011 | 07:18 PM
busdriver9's Avatar
You were spot on....worked like a charm!
Thanks for the help.
-Chris-
any tips on Valve cover gaskets?????
Old Feb 17, 2011 | 11:46 PM
SSfanatic's Avatar
Best tip with valve cover gaskets is don't over torque the bolts or you will crush the v/c and it will leak every time. Remember you are going to need 6 tube seals and a intake plenum gasket. Just snug them up until the bottom of the v/c is down against the cylinder head. Be prepared to spend some time digging the old gaskets out of the valve covers, some of them can really be baked in there. Replace spark plugs while you are there, and if the plug wires are soaked with oil put new mitsubishi wires on. The aftermarket ones work there way out of the plug holes over time and cause problems.
Old Feb 19, 2011 | 08:01 AM
busdriver9's Avatar
thanks for the tips. good to know these things going into a project. +1 on the Mitsubishi wires...I would of just went with the aftermarket wires. I planned on doing plugs and wires even know I had platinum plugs put in it about 35k miles ago. I figure while I have the intake off I should just replace plugs and wires. I will also clean the intake components while it is off. Anything to know about that?
Mitsu28
Feb 11, 2017 08:50 PM
raider22
Sep 4, 2014 09:08 AM
wilde
Sep 24, 2012 01:45 PM
n0c7
Mar 15, 2009 03:36 PM
Eclipsor
Jun 20, 2006 03:14 PM
