03 Monty LTD rear wheel alignment issues
Old Apr 8, 2011 | 05:50 AM
sn22's Avatar
Default 03 Monty LTD rear wheel alignment issues
Hi all, I am getting ready to do a 2" OME lift and know I will need to realign after its installed but the stealer said my alignment "pins" on the rear are frozen up and will be a real pain in the butt to actually use them. He said this is a common problem on the Montero's. Does anybody have any experience with this? Thanks for the help!
Old Apr 8, 2011 | 02:48 PM
mothman52's Avatar
Sorry, sn22, but there's nothing in my manual about alignment pins. Must be a newer feature on your '03 to add complexity where it wasn't needed Hope someone knowledgeable with your era's vehicle will chime in with some advice for you. All I can tell you is to put the weight on the vehicle on the ground before tightening your shocks to specs.
What size and brand of tires you going with?
Old Apr 8, 2011 | 08:55 PM
Mr. Z.'s Avatar
Originally Posted by sn22
Hi all, I am getting ready to do a 2" OME lift and know I will need to realign after its installed but the stealer said my alignment "pins" on the rear are frozen up and will be a real pain in the butt to actually use them. Thanks for the help!
Are they referring to the toe and camber bolts?
http://www.pajero4x4.ru/piii/GR00003400-34.pdf
If there are no other shops willing to do it without complaining, you could always use a breaker bar to free it up the bolts at home. Then apply some anti-seize before you take it in for the alignment.
Good Luck
Old Apr 9, 2011 | 09:31 AM
sn22's Avatar
Yes, thats what they are referring to, the camber adjustment bolt, they say it gets all corroded and it should be taken out and neverseized when the car was new. I told them thanks for telling me that now! LOL..... Ill get some heat on it and see what I can do. Thanks for the help guys....
Scott
lovinmrv
Sep 25, 2016 12:12 PM
7-UP BILL
Nov 1, 2014 01:22 PM
Tpaul
May 21, 2013 02:38 AM
lovinmrv
Jan 1, 2012 01:24 PM
ultramindbrk
Dec 10, 2007 07:10 AM
