1989 dash and running lights out..
Old Jun 11, 2015 | 01:23 PM
Jesse24's Avatar
Default 1989 dash and running lights out..
I have a 1989 Montero 2.6 SWB with dash and night time running lights out. The headlights still work. Rear bulbs are fine.
1. Are they on a relay or fuse? They did flicker for a while, but now totally out. I can't seem to find the short.
If my switch is broken, I'll just wire in switches on dash, but the wires are confusing me.
1. I took apart the switch and there are 3 wires to those functions. A red which reads -12 volt on ignition. A green constant -12volt. And a black ground.
2. The red appears to run head lights when grounded. The green doesn't seem to do anything, (I'm assuming that is the problem).
So I can wire the head lights, but still don't have the tail and dash.
Thoughts? Thanks.
Old Jun 11, 2015 | 05:52 PM
check your fuzes first. I'm sure there is a relay there too, because that would be too many light to run through a switch.
Old Jun 12, 2015 | 08:22 AM
Jesse24's Avatar
thanks, I'll go through them again and maybe just replace, they all look fine but who knows. I was hoping someone on here knew which fuse/relay that is?
Mark53
Jul 3, 2015 06:34 PM
MTRaider
Jan 19, 2014 12:21 PM
Jims M
May 1, 2011 07:52 AM
Monte98
Dec 8, 2010 01:46 AM
claytonkobe
Sep 19, 2010 12:28 PM
