1989 Monter 3.0 rough idle/hesitation ....thoughts?
Old Dec 21, 2020 | 09:59 AM
J2DD's Avatar
Default 1989 Monter 3.0 rough idle/hesitation ....thoughts?
Hello all. I just drove the Montero down to Todos Santos in Baja Sur last week. About 3 hours north, the CheckEngineLight came on, but without symptoms. My EGR TUBE had been patched with JB Weld and that finally melted off, so I replaced it with the spare I brought down with me. The CEL stayed lit. Then a couple of days later, I was driving down to Cabo and while accelerating up a hill, it started to pulse a bit (slight hesitation followed by acceleration). But it still drives fine other than that. On that same drive yesterday, no pulsing. But its running and idling a bit rougher than before. And the exhaust smells worse...
I retrieved the error code with a voltmeter - 42. Haynes suggests Fuel Pump (which is new) and to check Harness and Connector and/or the control relay.
Before I got the code, I took it to a local mechanic. He suggested it was the spark plugs and replaced them (only 4k on them). Still rough...starting to think sensors or ECU.
Anyone have experience here? I'm stumped.....Thank you....
glttrybuttrfly
Aug 18, 2005 11:18 AM
matt02708
Jun 12, 2005 10:24 AM
96EclipseGSX
Feb 14, 2005 09:07 AM
outlancer
Dec 11, 2004 09:36 PM
Salazar
Oct 4, 2003 09:36 PM
