1991 Montero RS: Limited Slip Diff?
Old Mar 15, 2007 | 03:39 PM
Mitsued's Avatar
Default 1991 Montero RS: Limited Slip Diff?
Hi, just purchased my first Montero, a 1991 RS last week.
I'm doing the usual "new to me" maintainence, new fluids, filters, etc. What I need help with is, how can I tell if my RS has a limited slip differential? Since LSD vs non-LSD require different gear oils, I need to know before I go out and buy the stuff.
Thx.
Old Mar 15, 2007 | 07:40 PM
off roader's Avatar
Default RE: 1991 Montero RS: Limited Slip Diff?
ORIGINAL: Mitsued
Thx.
Several indicators to look for...
1) Decal on door frame / door indicating an LSD
2) Decal/plate on differential housing near the fill plug
3) Chock the front tires (front and rear of front tires). Release parking brake and raise rear of vehicle and turn one of your rear tires. If the other tire moves in the same direction you have an LSD or locked differential. If it moves in the opposite direction then it's an open diff.
Way to tell if it's locked or an LSD is to turn at ~10mph and listen for tire slip/screetch. If no screetch then LSD. If screetch then someone welded the rear spider gears creating a full time locked differential.
HTH
Old Feb 20, 2008 | 07:37 PM
killerkaw's Avatar
I also own an RS. It doesn't have limited slip. ONLY the LS version, (as in Limited Slip) has the, well you know, differential.
Old Mar 23, 2012 | 09:50 PM
Janavish's Avatar
As mentioned before the RS does NOT have limited slip, The LS does. I have a 91 montero and i found an LS for parts SO im going to swap the LS diff in
aaron1969lopez
Nov 3, 2010 03:36 PM
VooDooFury
Sep 25, 2009 10:31 PM
19gst98
Apr 12, 2008 05:40 PM
matthew_m75
Mar 21, 2007 05:22 PM
racerx55
1st Generation
Feb 17, 2007 04:18 AM
