rear limited slip
Old Feb 16, 2007 | 03:32 AM
racerx55's Avatar
Default rear limited slip
Is there an easy fix for a cooked rear stock LSD? i got my GSX stuck in the 4 feet of snow in my driveway and it dont work anymore.I dont wanna weld it but now that i found dry pavement it spins one front and one rear on a hard launch & that just sucks ***
4th gear on the rev limiter for about 45 seconds to get it out of the snow but i made it to the garage.
Old Feb 16, 2007 | 04:41 PM
fcukwithmeprelude's Avatar
Default RE: rear limited slip
How bad did you cook your tires while doing that?
Looks like you might need to swap out some differentials.
Old Feb 16, 2007 | 05:03 PM
Well i think to change out the diff for that your gonna need to drop the tranny at least. So its not the easiest job to do
Old Feb 17, 2007 | 04:18 AM
racerx55's Avatar
i meant the rear diff, not the front. I know how to change it, just wondered if theres an easy way around a burnt up VC ( thats what the last one i seen had in the rear), i have another rear diff with the teeth torn off and the pinion ripped out of the housing i suppose i could swap some parts around. open diff in the rear sucks ***. I think the one good one i have is from a 3 bolt car so i dunno if that'll work or not.
Mitsued
Mar 23, 2012 09:50 PM
VooDooFury
Sep 25, 2009 10:31 PM
19gst98
Apr 12, 2008 05:40 PM
matthew_m75
Mar 21, 2007 05:22 PM
madmat
May 21, 2004 01:45 AM
