1995 montero engine swap
Old 05-26-2006, 03:46 AM
tusokuga's Avatar
Default 1995 montero engine swap
I am a proud owner of a 1995 montero with 3.0 single cam. I was wondering if i could swap out the 3.0 that is busted up with a 3.5 dohc. And if i could then what i would require for the swap
thanks,
alan
Old 05-26-2006, 04:20 AM
Default RE: 1995 montero engine swap
Anything's possible with enough time and $$$.
Seriously, you'll need to swap the...
1) Engine
2) Wiring Harness
And also probably the...
3) ECU
4) & possibly the tranny bell housing.
Old 05-26-2006, 02:26 PM
tusokuga's Avatar
I have the time and some money, the thing i want to know is if its just a drop in swap or a lot of fabrication. I just want to make it clear that the 3.5 would be of the same year, so i would imagine that it might work. I have searched the web for info on this swap but i have found nothing.
thanks,
alan
Old 05-26-2006, 10:22 PM
Do you have a doner vehicle? They're not necessarily easy to find.
You may also need to swap diff's (front and rear) as they are different on the SR model which has the 3.5DOHC engine.
May be cheaper & more reliable to buy an SR outright since they go for roughly 5k-10k these days.
shownuff80
08-26-2019 11:39 PM
callingdoug
12-23-2014 11:45 PM
The Mayor
09-03-2014 02:39 PM
Cid
05-01-2013 05:18 PM
matt02708
05-02-2005 12:02 PM
Quick Reply: 1995 montero engine swap
