2000 Montero Sport 3.0 High Idle
Old Dec 12, 2013 | 06:19 PM
Reddik's Avatar
Default 2000 Montero Sport 3.0 High Idle
Hello all, I am having trouble with the idle of my Montero Sport. Originally when cold it would stall and hesitate but once warmed up it would run fine except the idle would be about 1500. I cleaned the TB thinking that would fix it, and it fixed half., It now starts perfect and no longer stalls or hesitates, but the idle has now jumped up to 1600-1800. If you turn on the AC the RPM will drop to 1100 ish, and once in gear down to 750-800. Turn off AC and put in park and it jumps right back up to the High rpms. The only DTC is 0400 the EGR exhaust gas re circulation. Other than that she runs fine. Any assistance here would be great.
Thank you
Old Nov 30, 2020 | 03:32 PM
leojbourne's Avatar
Please what was the fix?
Old Nov 30, 2020 | 10:28 PM
Naeos_Valkarian's Avatar
Thank you
Try pulling the idle air control valve and give it a good cleaning if you haven't already, then if that didn't fix anything, start looking for vacuum leaks, and if you have a scan tool that can read live data, check the throttle position sensor, it should read 0% when no throttle is applied. Just a few to start with.
golfnovember
Oct 31, 2022 07:39 PM
cjean99
15
Feb 28, 2013 05:25 PM
JFENDERSON91
Oct 10, 2012 11:24 AM
johnaljay
Aug 3, 2011 11:51 PM
yamahablaster8230
Aug 29, 2006 09:28 AM
