2001-2006 Montero - Rear Door Trunk Not Opening
Old Jan 14, 2010 | 08:55 AM
cougar8000's Avatar
Thanks for the information guys. I will try to find time this weekend and get to it. I will post my results.
Old Feb 8, 2010 | 01:18 PM
cougar8000's Avatar
Last weekend I finally found time to get to it. It was a 25 min jobs. Removed handle and light. top panel first. Lower panel second. Pulled plastic out. Clean and lube that spring. Works like brand new.
Question is how the **** one lube that **** with out pulling all the plastic out? As it appears there is no way to lube it from outside.
Thank you all for providing perfect guide for this.
Old Feb 9, 2010 | 03:17 PM
Tantrix's Avatar
The only thing you can lube from the outside is the tumblers inside the cylinder lock. From inside the door (as me and a few other posters mentioned) you are able to lubricate the internal mechanism that opens/locks/unlocks the rear door.
Old Feb 10, 2010 | 08:18 AM
cougar8000's Avatar
Correct. That is why I asked that question. AS the problem was with an internal mechanism. Spring that operates it was rusted to a point that it was not moving anymore. Preventing moving parts to move.
Old Feb 21, 2010 | 10:03 AM
61jason61's Avatar
hi, that is why the interior door panels are removable with the door shut. I wouldn't have been able to fix mine without destroying something otherwise.
when i bought it door never opened. previous owner didn't think to try taking the panel off!!
Old Feb 25, 2010 | 05:26 AM
trainy's Avatar
I am going to lub it up, and as someone suggested. I would put a thin line of clear silicone across the top to prevent moisture from rusting things.
corycarbo
May 1, 2017 11:20 AM
OutlanderGT
Jan 16, 2013 11:54 AM
redturboeclipse
Oct 26, 2009 10:41 PM
pd154
Sep 7, 2008 11:55 AM
meatball18
May 26, 2007 05:10 PM
