2001 Limited Brake Issue
Old Dec 10, 2019 | 01:30 AM
digger26's Avatar
Default 2001 Limited Brake Issue
Hi, after i press the brake pedal and release it i hear a three second buzz or whine noise. I can hear it in the cabin and outside the vehicle. Sounds like it coming from the drivers side. Any guesses to what it is? Brake booster? Thanks!
Old Dec 10, 2019 | 01:23 PM
Most likely brake booster accumulator. Second possibility - brake booster motor.
Old Dec 10, 2019 | 02:51 PM
edpruss's Avatar
The ABS system is supposed to buzz when bleeding to refresh fluid?
Ed
Old Dec 10, 2019 | 04:37 PM
digger26's Avatar
Thanks!
I've owned the car for years and this is a new noise.
Any way to tell if it's accumulator or the motor?
Old Dec 11, 2019 | 12:40 PM
If the noise occurs only when you press the pedal, most likely it's a bad accumulator. Replace that (easy job) and see if it goes away.
A bad motor would be buzzing all the time trying to build up boost pressure.
Old Dec 11, 2019 | 11:22 PM
digger26's Avatar
Thank you !
dgrasho1
Sep 7, 2019 12:48 PM
wilde
May 31, 2016 01:11 AM
EsWeAr
Jan 8, 2015 02:11 PM
Z-drive
Feb 3, 2014 11:02 PM
lovinmrv
Aug 9, 2009 11:18 AM
