2001 montero sport XS persistent P0303 code
To have been getting a persistent P0303 (cylinder 3 misfire) code.
About 2 weeks ago I replaced the valve cover gaskets, plugs, wires, and EGR valve. After putting it back together it was idling rough. I assumed the computer needed to "relearn" the idle and followed that procedure. Upon test driving I got the P0303 code. I started chasing down this issue by replacing the cylinder 3 plug again, replaced the plug wire again, and the center coil pack. The code continued. I ran injector cleaner through with no response. The way it is idling with surges would point me towards the idle air control valve, but the P0303 code is throwing me off. It was running perfectly prior to the valve cover gasket change (other than leaky gaskets).
Any suggestions?
Any suggestions?
Last night I took everything back apart, for the third time. Checked every plug, wire, connection, etc. I put it all back together and erased the code. After testing everything is working fine. I'm guessing it was a bad connection. I don't know, just glad its working. Thanks everyone for the input.
2003EclipseRS
Oct 18, 2011 02:57 PM
Bnchs
Jul 7, 2006 03:29 AM
