2002 Limited Upper Glove box locked
Old Sep 7, 2014 | 08:31 PM
maco35's Avatar
Very nice.
Old Nov 21, 2014 | 09:17 AM
rubs65's Avatar
Hi All I'm from blighty and I have the Japanese import pajero with the same problem , but I don't have the key entry on the bottom glove as pointed out so how would I go about opening both of mine as they are both locked , the UK sight is helpful but I haven't found anything on there to show how to help ..
Old Mar 8, 2015 | 12:41 AM
redturboeclipse's Avatar
I forgot to point out when I first mentioned this, that yea there are 2 keys. One key won't open the glove box lock. So if you don't happen to have all the keys as if you purchased the car new, just hope the key you have is the one that also opens the glove box.
If not, the trick will still work, but you will have to do as one person did and pick the lock or have someone pick it.
Old Mar 8, 2015 | 11:26 PM
PalmSprings's Avatar
Default 2 glove boxes?
I never knew about the montero sport having 2 boxes. Must have been an option.
Originally Posted by alsaaron
Dude... thanks so much for these instructions! Just got a 2003 Montero Limited and started having trouble with the top glove box. Drilled a hole and, boom, there was the key hole. Key worked fine... switched the two locks as you suggested and it looks fine to me. Probably drilled too hard because I went into the lock a bit, but no big deal. Here are some pictures.
Old Dec 27, 2015 | 10:50 PM
Low Class's Avatar
Just had the same problem with my upper glove box on my recently acquired '03. Had me a little worried I would tear up the dash to get it open. Thanks for this thread!!
Old Feb 4, 2016 | 05:10 PM
I only have one glovebox. Were two an option? never seen 2 gloveboxes in anything......that i recall.
Old Feb 4, 2016 | 06:05 PM
maco35's Avatar
What year is your truck? mine also has 2 gloveboxes.
Old Feb 6, 2016 | 09:43 PM
Default were tandem gloveboxes an option in montero sport
mine are both 01s...oly have one. I mean how many gloves are you supposed to keep in your vehicle anyway?
Old Feb 7, 2016 | 11:10 AM
maco35's Avatar
I didn't see this post before, the full size Montero is the one with 2 gloveboxes.
Vadimus
Jun 28, 2012 06:59 PM
anywidget
Dec 2, 2011 03:13 AM
Punisher
May 19, 2006 04:40 PM
dsmturbo
Feb 9, 2006 03:13 AM
