2002 montero limited transmission problem
Old Mar 12, 2017 | 05:11 PM
evifansi's Avatar
Default 2002 montero limited transmission problem
I used non-Mitsubishi transmission fluid in my 2002 Montero limited. It didn't work, so I drained it and used Mitsubishi ATF SP III, but it has since not worked. It won't shift into 3 and when I force it, the engine heats up. Any help?
Old Mar 14, 2017 | 01:37 PM
MrGalantGuy's Avatar
Were you having issues with the transmission prior you do the initial trans fluid change?
SOunds like your transmission is done.
Old Jul 27, 2020 | 12:06 PM
Agibien's Avatar
I've recently replaced a transmission on a 2002 Montero Limited and it won't shift higher than 2nd gear. When I call the place where I got the transmission from, I was told to look into replacing the "free cycle switch". Any truth to that?
marcmindte
28
Jan 26, 2024 08:24 AM
big_country01
Mar 29, 2016 08:52 PM
rschoon
Jun 29, 2014 08:21 PM
NewYorkMontero
Dec 12, 2005 08:13 PM
firerice
Dec 1, 2005 07:13 PM
