2002 Montero sport ES V6 idle control valve
Old Jun 18, 2019 | 07:28 AM
tonybrooks625's Avatar
Default 2002 Montero sport ES V6 idle control valve
I keep having to change out the idle air control motor about every couple of months. Has anyone else experienced this and what did you do or what causes this?
Old Aug 7, 2019 | 01:45 PM
dthompson's Avatar
Default Idle Air Control Valve
I'm having the same problem with my 2001 Montero Sport. Replaced the IAC in 2014 with a cheap aftermarket part ($80). Started having idle problem again in 2019 with the P0506 code. Replaced the IAC with a $20 IAC and it still isn't working right.
Do I just need to bite the bullet and spend several hundred dollars for a factory replacement IAC? If I could get another cheap one to last four years I would be happy with that.
Old Aug 7, 2019 | 02:08 PM
2001Mitch3.5XS's Avatar
Default Junk Yard
Just grab one at a junk yard dude.. Tough to find Monteros in the JY tho so good luck bud.
Old Aug 7, 2019 | 03:11 PM
Have you done proper Idle re-learn procedure after replacing IAC? Agree with previous post - go with Mitsubishi part, not aftermarket!!!
Randys
Aug 12, 2013 06:07 AM
94GalantLS
Mar 29, 2006 01:40 AM
blkdoutek
Jan 25, 2006 08:58 PM
1398spdr
Mar 16, 2005 07:29 AM
