2002 Montero XLS No Parking Lights or Brake Lights
Old Jan 12, 2015 | 09:28 AM
Coops217's Avatar
Default 2002 Montero XLS No Parking Lights or Brake Lights
So I just noticed late last night that my parking lights are not on with my headlights. The blinkers work/hazards- but no parking lights. I didn't figure out until I was at work today that I probably don't have brake lights either. I'm thinking its a fuse. I have to run out during my lunch hour and check the fuses. I am reading that this could be an old battery issue? Bad Ground?
Is any one else having this issue? Help! Thanks!
Old Jan 14, 2015 | 11:01 AM
WhiteLightnin's Avatar
I just fixed the same problem ive had for the past month or so. I went off roading and bottomed out quite a few times. Coming home from my adventure, a cop pulled me over and said i had NO brake lights. Third brake light and both tail lights were out. I did the same as you and checked the fuse but all of them were alright and appeared working. After illegaly cruising around without brake lights for a few weeks, it dawned on me that my brake light switch must be screwed due to the harsh impacts during off roading.
My advice to you is to check your brake switch underneath the brake pedal. Get a friend to be behind your car and click the switch with your finger. Pushing the button in means the light does not come on, and it being fully extended out means the brake lights should come on. If it is not consistent evry time you do it, its needs to be replaced.
I went to Pep Boys, got the part for $27 and they wanted to charge me $90 for labor. One of their workers was cool enough to do it for $30 and in less than five minutes, i had brake lights AGAIN!
Hope this helped
Old Jan 14, 2015 | 12:37 PM
Coops217's Avatar
I'm not sure what happened but now I have brake lights, but still no Parking Lights. The bulbs all work because have hazards and signals. I cant seem to find a Parking Light switch or relay - does anyone have any idea how I get my parking lights back on? Fuses are all good.
Thanks!
Old Jan 15, 2015 | 08:09 AM
What exactly do you mean by you
have no Parking Lights?
Old Jan 16, 2015 | 08:59 AM
Coops217's Avatar
??? I fixed it thanks
Old Dec 29, 2016 | 03:51 AM
Lee Smith's Avatar
What was the problem and how did you fix it?
My 1989 Galant has the same problem.
Old Dec 30, 2016 | 08:07 AM
Coops217's Avatar
All of the bulbs burned out at the same time. All the fuses were good. Replaced front parking bulbs, and all rear stop/brake bulbs.
Old Dec 30, 2016 | 08:09 AM
Coops217's Avatar
The hazards have thier own bulbs, the parking bulbs burned out, and needed to be replaced.
Old Dec 30, 2016 | 11:03 PM
Lee Smith's Avatar
Smile Greatly Appreciated Buddy
Excellent and greatly appreciated Buddy, I will check the bulbs and continuity power supply.
corsair_105
Oct 19, 2013 10:27 PM
blueb16
Feb 27, 2011 01:33 PM
jp007
Dec 24, 2008 01:41 PM
rexbd
Mar 23, 2008 04:21 AM
nena604
Mar 4, 2005 07:37 AM
