2002 Montero XLS - AT/TC/diff fluid change.
Old Nov 17, 2008 | 11:07 PM
Trick's Avatar
Default 2002 Montero XLS - AT/TC/diff fluid change.
We have a 2002 Montero XLS with that has almost 80,000 miles on it. The AT fluid still appears to be pinkish in color with no burnt tomato smell (not sure what the smell is anyway.) The AT shifts fine and feels great. Should we replace the fluid? If so, should it just be a drain and refill or a flush?
There are mixed comments on changing the fluid. Some say leave it alone, others say change it... some say changing the fluid will cause problems, others say *not* changing the fluid will cause problems.
What about the F/R diff and transfer case? The Montero is not used off-road or in the dirt and has never towed. Should we change the fluid as well or leave it as is?
So I am looking for the Mitsu experts who know these issues. It would be great if I can get a clue... I am a Jeep guy and I change the fluids in Jeep often as it see's a lot of off-road use. I just don't know much about how well Montero holds up.
FYI, the Montero was bought new...
Thanks!
Old Nov 18, 2008 | 05:33 AM
4g54's Avatar
Default RE: 2002 Montero XLS - AT/TC/diff fluid change.
just follow the maintanance schedule.
autobox are sensitive to the fluid.
drain&refill is enough but flushing is better.
same goes for the axles, and transfer case.
Old Nov 18, 2008 | 09:27 AM
carlover626's Avatar
I have heard a lot of people having a tranny fluidflush/change done with the wrong fluid and having problems.Just had mine done ~10K miles ago and no problems to date at 104K miles.
You said that normal maintenance is always performed...I think all three of these items are recommended every 30K(a bit excessive)under the severe schedule.
Old Nov 21, 2008 | 04:56 AM
Skiddy's Avatar
I would change them as preventive maintenance. Your '02 Montero will require SP-III ATF, which you can also purchase at Hyundai dealers. Try and get it flushed if you can, to get all the old fluid out of the system.
I change my transfer case, differential, power steering fluid regularly every 50,000 km (30,000 miles). ATF I change every 35,000 km (22,000 miles), along with brake fluid and coolant. That being said, I follow the severe service schedule because of local climate and traffic conditions.
Turbo351
Mar 7, 2025 04:07 PM
mrlimey
Jan 26, 2018 11:12 PM
newoutlanderfan
May 27, 2013 10:47 AM
matthewm1965
Apr 22, 2011 01:34 PM
jacubsuk
Sep 7, 2004 05:34 PM
