2002 XLS Montero Sport 3.5L no start, intermittent
Old Apr 21, 2019 | 06:49 PM
cesurasean@aim.com's Avatar
Default 2002 XLS Montero Sport 3.5L no start, intermittent
I am currently having problems with a 2002 Montero Sport XLS 3.5L no start.
It seems to only happen when engine is hot.
When it happens;
you can hear sound, 1 click from starter ( this is a new starter and battery, and starter relay, and ignition switch )
when you put car into reverse or park, you can hear a weird humming sound, and this also seems to manipulate the clicking coming from the starter.
is it a bad neutral safety switch?
The problem seems to be when engine is hot and intermittent.
Thanks,
Sean
Old Apr 26, 2019 | 10:51 AM
It was not starter, starter relay, battery, or ignition switch.
I keep finding horn fuses blown.
I suspect the horn fuse/horns are causing a short while unplugged which is activating the alarm/anti theft system. When this happens, ONLY a jump from another car will get me going on.
My solution is to fix the airbag switch or add an inline switch through where the horn fuse goes.
-Sean
Old Apr 26, 2019 | 10:52 AM
or was NOT the neutral safety switch.
Steve58
Jul 24, 2017 03:38 PM
anothermontero
Sep 17, 2016 12:57 AM
xocomil
Feb 6, 2014 11:43 PM
