2003 Montero Limited won't crank
Old Nov 3, 2023 | 08:52 PM
03MonteroLMT's Avatar
Default 2003 Montero Limited won't crank
Hi, new to this forum, although I've read a lot threads regarding my 2003 Montero Limited 3.8L.. It's a great vehicle, and I'd like to keep it a while.,,,
The SUV has a new battery, and all lights, etc. are lighting up as expected. When I turn the key to the start position, nothing happens. I've had the key replaced a year or so ago, and had to use the brake code trick to bypass the immobilizer and drive it to the dealer to get the key programmed. All has been working well since then, until the car refused to crank like the immobilizer was activated.
I checked the fuses, and would like to check the starter relay/fuse before have to have it towed. Can anyone share where and how to get to the starter relay, or any other helpful info ? I've been searching the internet, yet can't find much. I called the dealer, and they would not help. Thanks in advance. .
BKCaspy95
19
Dec 10, 2022 04:24 PM
Xjfire
Feb 20, 2021 09:22 PM
taybrynn2
Apr 27, 2018 01:42 PM
navidbe
Oct 11, 2013 07:37 PM
navidbe
Mar 19, 2013 02:45 AM
