2003 Montero Sport 3.0 V6
Old Jul 24, 2015 | 05:31 PM
Drummerboy88's Avatar
Default 2003 Montero Sport 3.0 V6 Help Pls
I have code p0303 on for cylinder 3 and i checked the coil going to cylinder and it did have an intermittent spark to it and so naturally i changed it. But i still have the code on and the car is still running rough when in drive and at idle or even picking up speed. Need help. Thanks.
David
Old Jul 24, 2015 | 11:25 PM
It could be as simple as a bad spark plug wire or control. I once had a misfire code for cylinder #5 and it was due to spark plug wire (plug end) swelling from an oil leak into the plug well. That made the wire pop off the spark plug and causing an intermittent misfire. Also, check wire for the other plug that feeds from the same coil. Both sparks on single coil fire at the same time and it is possible that the other cylinder is the one with the problem. Look on the intake manifold for cylinder numbers which correspond to the coil. Don't forget to check the primary coil feed wires. Make sure the connection there is good and you have signal.
Old Jul 25, 2015 | 03:31 PM
k thanks will give it a try.
avizcarra
Oct 1, 2008 02:42 PM
nvpurk
Jan 19, 2007 08:30 PM
fguilarte
Oct 29, 2006 01:10 AM
Tractor77
Jun 14, 2006 03:20 AM
jpardinas
Oct 19, 2005 11:30 AM
