2003 Montero sport Issue after not running for 5 days.
Old Mar 17, 2022 | 09:29 AM
montero sport man's Avatar
Default 2003 Montero sport Issue after not running for 5 days.
Hi everyone, I have a 2003 Montero Sport with the 3.5L engine, and after letting it sit for 5 days or so, I got in it and started it, and it was only idling at 700 rpm or so. sorta sounded like it was choking or something. I blipped the throttle a couple of times and it rose to the normal 1500 rpm when it’s warming up. Waited for it to warm up and drove it and when i gave it gas it would try to die then eventually pick itself up. Started it the next day and it started fine and idled fine and when I put it into gear it was fine, but when it got to operating temp, it started to die when I put it in gear, then eventually it would begin to die in park if I left it running long enough. Idk if it could be fuel pump, IAC, etc. Seems to me like it’s not getting fuel because when I hit the throttle it will sound normal. If I hold the throttle at a constant 2000 rpm, it will stutter consistently like it isn’t supplying enough fuel. Also, I do not have an engine light on.
Any responses are very much appreciated, thank you guys for your time.
Old Mar 18, 2022 | 02:26 PM
You might be on thevright track with fuel. I'd check that first. Could be a fuel pump or plugged fuel filter.
Old Mar 18, 2022 | 02:47 PM
@HunterD started it today and it ran perfectly fine, drove perfectly fine, and when it got up to temp it ran and idled perfect. I don’t understand it, to me it seems like my fuel pump is just waiting to crap out…
Old Mar 18, 2022 | 10:17 PM
Do you experience longer than usual cranking time when starting cold?
Noahp45
Oct 6, 2022 06:06 PM
Jellyroll494
Jul 29, 2021 08:21 AM
Dddowns
Apr 6, 2020 05:42 PM
Bremboy71
Sep 12, 2019 08:45 AM
JTE7690
Nov 15, 2004 05:18 PM
